brakes!!!
Old Oct 8, 2011 | 05:20 PM
  #21
keato's Avatar
Thanks alot for that mate,, does the axle and diff look formulary to you???
Old Oct 8, 2011 | 05:27 PM
  #22
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
Yes sir. That is the same type 10 bolt rear that I have in my 72.
Old Oct 31, 2011 | 05:52 PM
  #23
bad436z28's Avatar
did u find out the resolution to your brake problem,i still say its the booster.have fun and enjoy ur camaro.
Old Nov 5, 2011 | 11:09 AM
  #24
77 kencraft's Avatar
All of the above, sounds like the power booster, try plugging off the vacum hose to your booster, a 3/8" bolt usually works good and see how the pedal feels, don't drive like this it could be dangerous. Does the pedal feel the same with engine running as apposed to not, are you getting vacum to the power booster?
Old Jan 19, 2012 | 02:34 PM
  #25
keato's Avatar
i have been back out at the camaro now that the weather aint so bad,,
bleed the brakes ok and still nothing,, i have power brakes and when i press the pedal down i can hear a hissing in the car, would that suggest that the booster is bad,, should i just replace it
Old Jan 20, 2012 | 08:52 PM
  #26
jeff 1980's Avatar
I had the same problem before first thing is check the fluid level.then check to see if the vacume line is connected to the brake booster it should go from the booster to the back of the carb make sure its not leaking air and if thats good get a friend to help you bleed the brakes pump it ten times and hold then open the bleeder till the pedal goes down then close the bleeder repeat for all 4 start with back passenger side then back driver side then front passenger then driver front if it still dont get better you might have to replace booster
Old Jan 23, 2012 | 10:19 AM
  #27
keato's Avatar
have blead the brakes,,no air in the system at all,, as i say there is a hissing noise when i press the brake pedal,, the vacume is connected to the carb and it isnt leaking either so its gotta be the booster rite???
Old Jan 23, 2012 | 11:09 AM
  #28
5time F's Avatar
Yes sir.. the hissing is the booster blown or dry rotted on the inside. Replace that bad boy.
Old Jan 24, 2012 | 04:51 AM
  #29
keato's Avatar
ok so i ordered a 9" booster few days ago,, the guy just emailed me to say that they where out of stock and cannot get them again but he has 7" booster,, would this work ok on the camaro
Old Jan 24, 2012 | 10:00 AM
  #30
The 7" booster is great, and a better choice to get a little more engine clearance. I would get it.
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
