Body Mounts
Old Jul 14, 2008 | 05:06 AM
79projectZ28's Avatar
Default Body Mounts
So I was changing the body mounts on my car this weekend, when I got to the last one (naturally) the nut started spinning. Anyone have this happen to them yet? If so, how did u fix it? Am I going to have to cut a hole in the floor pan from inside to gain acces to it? Its the body mount under the drivers seat.
Old Jul 16, 2008 | 09:07 PM
kyphur's Avatar
Default RE: Body Mounts
Are you talking about the one that's right behind the wheel well and is attached to the frame by a flange coming off the frame rail?
Old Jul 17, 2008 | 05:02 AM
Nope, its the one underneath the drivers seat, towards the back of the subframe. Where the subframe connectors go.
Old Jul 18, 2008 | 02:25 PM
daltons 1980's Avatar
cant u just torch the bolt off?
Old Jul 18, 2008 | 04:20 PM
The subframe bolts thread into a nut that is welded (usually tacked) to the body, and is usually buried in a cavity. He's saying that nut is spinning.[:@]
If you can't see it from above, under the carpet, I'm afraid you need to go digging for it. I know it's the same way with the leaf spring front mount to body bracket.
Old Jul 18, 2008 | 07:58 PM
Thats what I was afraid of (digging in a virgin floorpan)[sm=smiley19.gif]
Old Jul 19, 2008 | 01:06 AM
You can cut a small opening on three sides and fold it open. After you fold it back down,either weld it shut, or silicone it. Either way, you won't see it after the carpet is back down.
Old Jul 21, 2008 | 05:01 AM
Thats exactly what I am going to do, once I get done my Hotchkis suspension .
CamaroNut
General Racing/Tech
Oct 15, 2009 12:12 PM
He_named_me_Nicole
May 5, 2009 12:02 AM
portage69
Oct 11, 2007 11:03 AM
mattvogt
Sep 8, 2006 12:08 PM
tazkes77
Nov 26, 2005 06:50 PM
