Big block
Old Mar 10, 2006 | 04:34 PM
clone209's Avatar
Default Big block
I just got a 68 camaro and wanted to know if a 454w/headers will requiere any altering to the car and what problems you might of heard about in doing that.
Old Mar 10, 2006 | 11:00 PM
mattvogt's Avatar
Default RE: Big block
no it shouldnt since I belive they came with a big block option. also if it didnt, just frame mounts and suspension upgrades to handle the weight.
good luck
Old Mar 13, 2006 | 03:53 PM
68maro's Avatar
I have a 68 camaro with a 454 HO crate engine with headers. If your Camaro has small block engine brackets youll need to replace them with big block engine brackets they look similar but the engine sets differently. I purchased and installed Hooker headers they fit fine you may need to make a small dimple on drivers side header due to steering box interference. Depending on headers drivers side may need to go in before engine or if engine is already in you may need to remove motor mount bolt and jack up engine due to again steering box interference. I recommend you install a gear reduction starter with this combo. First easy starting, second the starter motor is smaller in size and leaves more room away from the headers. Good luck.
Old Mar 13, 2006 | 03:59 PM
68maro's Avatar
Also you'll need to replace front coil springs to compensate for the extra 150-200 pounds in the front end. If you decide on HEI ignition its tight fit but it will fit. Your new problem is going to be traction
Old Mar 14, 2006 | 02:12 AM
firebird69racer's Avatar
dont forget about the driverside valve cover if you have powerbrakes, it needs to be short
Old Apr 20, 2006 | 03:04 PM
67454conv's Avatar
You will also need a BB heater core box or remove the heater . The engine will keep you warm enough anyway. By the way I have SB perches in mine I just attached them to the engine set the engine and tranny back in (m-21) hooked up linkage measured for square and reattached the perches to frame everything lines up works fine
Old Apr 23, 2006 | 12:45 PM
1969 SS's Avatar
all good points stated here.
the thing with headers is they vary from make to make. the steering box is almost always an issue. the stock booster for the brakes is usually another problem, although they sell small boosters to remedy this problem. you have to use low valve covers for the stock booster, but if you have rollers these won't fit. your distributor will wit fine unless you use small block mounts because they set the engine a little farther back then the big block mounts. if you are just running a small cap distributor, this will not be a problem though. you will need better front springs. as far as th heater box goes, they don't make different ones for BB vs. SB. all they do is take the same box and drill new holes. save yourself around $100 and drill your own and just weld in a little bracket inside it to hold you core from moving, then fill the holes in the firewall where the old lines came out.
decaen
Feb 16, 2012 01:08 AM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
