aluminum heads
Old Sep 3, 2007 | 09:03 PM
daltons 1980's Avatar
Default aluminum heads
hey ......sorry guys still waitin on a lazy freind to get his camera for pics but its painted and rollin now....but im thinkin in the future i kno i cant leave it alone....will alluminum heads hurt me that much for gas and give a noticable diffrence?...becuz i wanna have a cool good runnincar but it is my daily driver..but now that i have it out and on the street it feels like such a dog...idk what its got for a rear but they must be pretty tall....(w/e came stock in a 1980 berlinetta) ..thanks
Old Sep 4, 2007 | 03:01 PM
434camaro's Avatar
Default RE: aluminum heads
aluminum heads are the way to go,,,they will only hurt you if you raise the compression,,,,what size engine do you have now,,,a 350 has 76cc camber heads and a 305 has 58cc camber heads,,considering it is the origanal engine,,,you can run 11.1 compression with a alum. head and still get away with pump gas,,,but the more you raise your compression the more camshaft you with have to add,,also the more you raise your compresion the hotter the engine will run also,,,if it is a 350 you can get alot of power with heads and cam,,,,i had a 350 with 58cc camber heads (which bumped up the compresion to 10.5.1) and a bigger cam (if you are going to do this i will let you know the specs),,and the car in street trim went 12.42 in the quarter,,,not bad for $1500,,,,what ever you do stay away from the pro comp heads
Old Sep 4, 2007 | 03:03 PM
434camaro's Avatar
the rear gears are most likly 2.73 or 3.08
Old Sep 4, 2007 | 03:41 PM
alright thx yea its a 350 out of a truck that i dropped in and it has a small cam in it now..nothin radical just enough to rumble...yea its gonan run pump always ...and its stock pistons and and rods and all...i figured a street car didnt need all that much...but i wanted to get a set of aluminum heads(when ig et the cash)cuz they look cool and should help it breath
Old Sep 4, 2007 | 03:43 PM
o and yea idk anything about the gears but 2.73 sounds farmilair...its the stock one legger w/e it is its not gotta stick around too long
Old Sep 4, 2007 | 04:06 PM
434camaro's Avatar
well if it is not the origanal engine from the car then pull a valve cover off and get the numbers so you can check and see what cc camber they are,,,a 1980 camaro 350 would have 76 cc cambers,,,,but being it is not the 80 camaro engine it could have 64 66 70 72 76 cc cambers,,,this is what you need to now before you do anything,,,also how many miles are on the engine because if it is a high milage engine chances are it will start to knock when the top end see's the pressure
Old Sep 4, 2007 | 04:22 PM
yea ill look into it alittle later...its should be fairly new when i got the car i was told itsa crate motor taken out of a rolled like blazer or somthin...and we completley rebuilt it soits all fresh....
richard.nelson100
Dec 31, 2011 03:28 PM
ATM
Nov 27, 2011 10:18 PM
gfrench
70-81 V8 Tech
Jun 6, 2010 01:46 PM
speedy9220
Oct 2, 2008 12:12 AM
metalupyr
Jul 18, 2007 06:05 PM
