Can't get it running, bout to kill it
Old Sep 3, 2007 | 01:57 PM
Dadrulesathome's Avatar
Default Can't get it running, bout to kill it
78 X28 Camaro
350 bored 30 over stock pistons
new edelbrock performer 202 heads
new edelbrock performer cam
new edelbrock performer intake
new holley fuel pump
edelbrock 600 carb
HEI dist
short LT1 plugs
timing is 12 deg
idles fine,
when you excellerate from idle, lag and bang die and hard to start
Is a 600cfm carb big enough?
It will not even idle down the street
Old Sep 3, 2007 | 05:46 PM
Default RE: Can't get it running, bout to kill it
I am only getting 7 in of Hg at idle????????
Old Sep 3, 2007 | 06:17 PM
74454bb's Avatar
May 2007 ROTM
Set the timing to 6 or 8 deg and see how she does..and yes 600 cfm is fine.
Old Sep 3, 2007 | 07:11 PM
Is that 4deg going to make that much difference?
and that should be without the vac advance plugged in?
Old Sep 3, 2007 | 08:17 PM
Chappie99's Avatar
Is your vac line ported, or to a constant vac source? Check that the advance weights are not stuck.
Old Sep 4, 2007 | 11:20 AM
riceeater's Avatar
while you may have too much timing, I would also try going higher, my car I had set at 13 degrees, sent it higher, the probs went away
Old Sep 4, 2007 | 03:14 PM
Ported
New HEI
but what could cause it to have such a low vac? (other than an obvious leak)
Old Sep 5, 2007 | 03:39 PM
Duh.......... spark plug wires off by 1...........................................I feel sheepish
Roachz28
Apr 20, 2011 12:31 AM
383Stro
Oct 25, 2009 01:49 PM
behindyou
82-92 V8 Tech
Oct 4, 2009 06:38 PM
The Reborn Phoenix
Jul 29, 2009 02:27 PM
383Stro
Apr 15, 2009 08:27 PM
