Are all U bolts equal length?
Old Jan 13, 2011 | 11:29 PM
tattoo400's Avatar
Default Are all U bolts equal length?
Is it possible for a U bolt to just be longer on one side??
Old Jan 14, 2011 | 02:34 AM
james hellsing's Avatar
Hi welcome to the forums! to answer your question, yes, it is possible. No company would take the time to measure a U bolt down to a tenth of a milimeter, so therefore each one will have flaws in length. Obviously this isn't the answer you wanted or thought you deserved but since you thought you needed one right away here you are. Obviously you could take the u bolt out and look at it to see if its equal or not, from your other post I'd say the size isn't right so a longer one might work better, as for will it work fine the way you have it, who knows, really its an accident waiting to happen.
Old Jan 14, 2011 | 02:45 AM
And you might post a pic of this problematic u-bolt of yours.
Old Jan 14, 2011 | 03:29 AM
brownstone101's Avatar
uhm.. The u bolt on the rear axle.. just replace them if its at question why your at it upgrade it, done
Old Jan 14, 2011 | 10:20 AM
Excess length is not common, but it's also no real concern. If it's working leave it alone.
Edit-If this is in reference to your other post about U-bolts on the U-joints, then you should replace them! They are not the same as U-bolts on the rear axle. Might want to specify which you are referring to next time, or only post once for the same question.
Old Jan 14, 2011 | 02:42 PM
StoveBolts's Avatar
I just saw you had two posts asking the same thing. Just in case you don't see the other post, I'll just do a copy paste here :-)
If you're worried about your u-bolts, why not just purchase a new pair? As far as one side being longer than the other, it almost sounds as if you tightened one end before tightening the other end. When you put your u-bolts in, make sure they are even from the get go, and tighten them down evenly by going a couple of turns on this side, and then a couple turns on the other side.
I'm curious as to what happened to your drive shaft. Did you just wear out a set of U-Joints or did you rip the yoke off your drive shaft?
Old Jan 14, 2011 | 04:51 PM
80ZJoe's Avatar
July 2010 ROTM
He knows about the other thread, he knows how do delete them too lol
Old Jan 14, 2011 | 05:49 PM
LOL, noticed that too huh Joe.
Old Jan 14, 2011 | 06:23 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
i notcied it too but havent posted on it lol, lets just say, no i better not lets imply hes acting like a word that starts with n middle is oo and the end is b =]
carguylt1
Mar 4, 2012 04:46 PM
awake1630
Apr 2, 2008 11:04 AM
wilbglc
Apr 17, 2007 03:00 PM
harvick boy
Nov 15, 2006 12:46 AM
gotalcoholmanup
Jun 28, 2006 02:29 AM
