driveshaft length
Old Nov 14, 2006 | 09:55 PM
harvick boy's Avatar
Default driveshaft length
I have a 89 rs with a 2.8. I'm upgranding to a 350+ with a turbo 350. I was wondering if the same shaft would work. any help is greatly appreciated.
Old Nov 14, 2006 | 10:10 PM
1983camaro's Avatar
Default RE: driveshaft length
no, the drive shaft from the 2.8 wont work as the 350 v8 and 350 Turbo together is longer in length. when you go to get a drive shaft , make sure that you know whether the ( 350T) transmission has a long or short tail shaft. you should also probably get new U joints for the new drive shaft as well.
Old Nov 14, 2006 | 10:38 PM
Thanks. Is there a model name for the driveshaft I'll need or will I need one made?
Old Nov 14, 2006 | 11:03 PM
1983camaro's Avatar
no model i dont think. just go to a dealer and tell them you have a late eighties camaro with a 350 v8 and a 350 turbo transmission , and that you need a drive shaft, before you go to the dealear ship find out whether the 350T as i said has a short or long tail shaft.
Old Nov 15, 2006 | 12:46 AM
uncle bill's Avatar
Go to a driveshaft shop and get one made. If You can't figure out the length, tow the car over there and have them measure it for You.
85olds4spd
Nov 8, 2008 01:58 PM
wilbglc
Apr 17, 2007 03:00 PM
GRIFF
Mar 15, 2007 02:48 PM
gotalcoholmanup
Jun 28, 2006 02:29 AM
