78 tail light harness in a 71 HELP!
Sorry for the miss communication but yes the whole harness is from a 78. Good idea about turning the back up lights into brake lights or turn signals. Will the lenses from the brake lights fit in the back up light pockets, they look to be about the same size. I have an electrical engineer that works for me coming up with a way of putting a couple of relays in the truck that may allow the stock configuration work. All the wiring drawings do not have specifics on the switches and how everything is wired to the different contacts, I would have to spend a ton of time with a volt tester to figure out how everything works.
I totally could not tell that you were still using the clear lens, I had to do a double take on your pic and still could not tell, thanks for the info makes my life a little easier. Were did you buy the LED's and do they have them in both 1157 1116?
Yes they have them in both. I bought mine from Vintage Impressions, aa company my friend owns. He sells these for alomost anything, but unfortunately they don't make them for a '71, so I used 58 Chevy truck LED tailights. They come with a round red lense that fits perfectly inside the Camaro lense, and have a pigtail with a standard lamp base on the end so they can plug into the factory socket.
I simply removed the backup socket, wired in another socket from NAPA and installed it in the backup side of the lense.
I used this style, but got them for less than half that price.
http://cgi.ebay.com/ebaymotors/1958-...ts_Accessories
lonestarshinedown
06-08-2015 12:39 AM
Mister
08-30-2006 03:44 AM
