tail light wire harness
Old Feb 6, 2011 | 03:58 PM
thetal1's Avatar
Default tail light wire harness
I need a whole tail light wire assembly for a 95 camaro. All 6 sockets and 2 side marker lights. Ive replaced it before and now its still cutting out (the turn signal). The turn signal light is way sensitive and will not stay in contact with the bulb.
So i would like to get a whole replacement harness but dont know where to get a new one from.
Old Feb 6, 2011 | 05:29 PM
have you tried to replace just the socket? only harness youll get is a used one or maybe painless makes one, check there website.
Old Feb 6, 2011 | 05:46 PM
AlaJoe's Avatar
Like Craby said. Get a socket. I did this just last weekend. I had one bulb in my tail lights and one of the side markers that the bulb would just not hold securely. I picked up new sockets at advance auto. Autozone has them also. They were 5-6 dollars. I spliced them together with heat shrink solder-less connectors.
Old Feb 6, 2011 | 07:16 PM
osduck5's Avatar
^^^^ Agree with above posters!
Old Feb 6, 2011 | 07:51 PM
thetal1's Avatar
alright ill try it. I just tried taking off the housing and pushing the contacts forward so hopefully that might help. if it doesnt work ill just go buy another turn signal socket
Old Feb 7, 2011 | 01:08 PM
Massey's Avatar
Make sure the lead dots on the bottom of the bulb are not all melted and flat. That will make a good socket seem bad really fast.
Massey
lonestarshinedown
Jun 8, 2015 12:39 AM
jenz
Jan 26, 2015 09:28 AM
oldstreetracer
Aug 11, 2010 09:57 PM
