78 rear axle swap
Old Mar 9, 2013 | 04:43 PM
  #21
Just make sure you find EVERY piece that breaks off, or you'll be replacing the rearend soon!
Old Mar 10, 2013 | 02:09 PM
  #22
mike6208's Avatar
do any of you guys know if any local stores, autozone ect sell the cross pin? i got the bolt but cant find the pin anywhere. searched orileys, autozone and napa.
Old Mar 10, 2013 | 04:22 PM
  #23
Most likely because the pin isn't a commonly sold replacement part to make it worth keeping one in stock. Rockauto.com has em, and a GM dealership might too.
Old Mar 10, 2013 | 07:11 PM
  #24
oldman9's Avatar
I found mine at orileys in the section that has ''help'' stamped on everything.
Good luck.
Old Mar 11, 2013 | 10:15 AM
  #25
The hardest part will be getting anyone at the chain stores who can find it in their system! Even if they have it, it will be a miracle if you can locate it online, or in the store!
Old Mar 13, 2013 | 09:15 PM
  #26
mike6208's Avatar
got the new shaft pin from a chevy dealer near me. guy told me the part number changed 3 times over the years. here is a pic of the part # if anyone ever needs it.
Old Mar 14, 2013 | 10:08 PM
  #27
v8chvyguy's Avatar
Are you changing the entire rear end or just installing internals. It's a bit confusing when you state that the 3.73's are in and then you're back to removing the center pin with a hammer. I'm interested because the photo you posted on pg.1 of the diff w/o the cover looks like it had a 2 series gear in it.
Old Apr 21, 2013 | 11:35 PM
  #28
millpondmonster's Avatar
I've always dropped the rear shackles on the leaf springs to drop them, and simply slid the housing down the springs to remove. Much easier than dismantling the rearend, or fighting exhaust and backing plates over the springs.
2nd that..............
crazyleroy
Aug 13, 2012 06:29 PM
bigfitchy11
Apr 28, 2012 05:22 PM
chucklebuckle121
West
Nov 19, 2010 06:28 PM
chevy_man
Feb 15, 2008 09:33 AM
t4nk
Aug 30, 2006 02:10 AM
