70 camaro tailights leaking help
Old May 16, 2011 | 10:58 PM
Texas70z28's Avatar
Default 70 camaro tailights leaking help
does anyone have any pics on how 70 camaro taillights should fit/look,mine show about 1/4 inch rubber gasket around chrome ring. My trunk filled up with water leaking around tailights, they fit kind of loose around the chrome ring but seem to be pressed up against car tight. any tips/tricks on how to fix? weather adhesive?
Old May 17, 2011 | 08:49 AM
They should show some of the weatherstripping, and it sounds like your's is right, but probably old. I'd just order the new rubber rings and slip them in. Really easy fix, and they're still available.
$29 for the set at NPD and the #C-2660-6AK
Old May 18, 2011 | 08:26 AM
Texas70z28's Avatar
Ok thanks, i also noticed the top bolt on tail light housing barely comes thru hole so nut wont tighten. I think the hosing may be warped but the whole assembly seems to fit tight anyway.
Old May 18, 2011 | 08:57 AM
NPD also has new housings to drop your assemblies into if it's warped. I think I'd be pulling the nuts and see what's going on that would allow so little stud to protrude through the housing. If the nut wont tighten that will also cause the leak. Might want to get new nuts too, so they grab better.
I had one ear on my housing that was broken off, so I used a big fender washer to get to good plastic that would pull down.
Old May 18, 2011 | 09:39 PM
Texas70z28's Avatar
I cant believe those bolts are not threaded,its got like flimsy thin metal nuts that cut into metal,only place i ever saw nuts like that were on plastic bolts? i bet i do need new ones so they cut in deeper.
Old May 19, 2011 | 03:44 AM
Ole Blue '74's Avatar
nope, Im just lookin for a tail light connector for a 74 camaro, year one only had up to a 73 but not a 74 why did chevy decide to change the connector for 1974 I have no idea but that engineer is a complete dumbass! there was no reason for them to change.
Old May 19, 2011 | 08:21 AM
Check your local NAPA store. I found they have what you want in their Ecklin catalog, and if it's not at the store they can bring it from their warehouse.
Old May 19, 2011 | 08:24 AM
Got to thinking last night (sometimes that can be dangerous!)and I remember a friend bringing his early 2nd gen over because he couldn't get the nuts to grab on those studs.
When we took it apart I found someone had put some dense foam double sided tape under the original gaskets to try to make them thicker, and seal better. You might pull the nuts and see what the seals look like, and maybe somebody was messing with them in the past.
Old May 19, 2011 | 10:02 PM
I'll have to check that out!
Phalen123
May 23, 2010 12:09 PM
nazariol
Jan 3, 2010 04:04 PM
RFxCamaro
Mar 8, 2009 11:18 PM
dcreal22
14
Jan 22, 2008 02:11 PM
gamer34
Nov 16, 2005 12:46 PM
