70 Camaro LS1 Conversion motor mounts short or tall
Old Aug 20, 2011 | 01:31 PM
f1hansen's Avatar
Default 70 Camaro LS1 Conversion motor mounts short or tall
I have a 70 Camaro I am putting a LS1 in it and I noticed that there are 2 types of mounts there is a small block and a big block which is a little shorter I am looking for the pro and con my thought would be if i can use the shorter one would be nice ?
Old Aug 20, 2011 | 01:32 PM
f1hansen's Avatar
70 Camaro motor mounts short or tall
Old Aug 20, 2011 | 05:29 PM
Oil pan to crossmember clearance. Thats the con. I'm sure the conversion mounts were designed around sb mounts.
Old Aug 20, 2011 | 05:56 PM
Doesn't make sense. The small block mounts are shorter than the big block. The big block are the taller motor mounts.
Old Aug 21, 2011 | 12:07 PM
f1hansen's Avatar
The bb needed a shorter mount for hood clearance. The mount I am talking about is the one that bolts to the sub frame.
Old Aug 21, 2011 | 12:59 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
Take a look over on ls1tech.com. IIRC most of the threads I have seen over there on the subject the guys are using either BB mounts or plates.
Old Aug 21, 2011 | 08:20 PM
That's sort of correct, but not completely correct. The BBC Camaros used shorter frame mounts, but taller motor mounts. SBC's used taller frame mounts, but shorter motor mounts. The complete assemblies are almost identical in height.
The BBC is slightly taller, and for hood clearance they ran a very unique lower than normal intake to get the needed hood clearance. I've gone round and round with parts guys over this for 38 yrs. that I've owned my BBC Camaro. Constantly getting the wrong motor mounts unless I take mine in and match them up to what they have on the shelf.
Old Sep 2, 2011 | 09:42 PM
jerhofer's Avatar
July 2011 ROTM
I used the SB mounts to install my LS1. Engine fit like a glove.
You can see them on my LS1 install thread.
https://camaroforums.com/forum/proje...-camaro-62476/
PiN
Mar 24, 2013 09:33 PM
MIKE O OCONNELL
Apr 24, 2012 12:29 AM
aman12
Jun 11, 2010 10:57 PM
91_camaro
Feb 11, 2007 11:26 PM
ZL1innovated
Dec 5, 2006 03:16 AM
