Motor Mounts
Old Feb 9, 2013 | 11:59 PM
PiN's Avatar
PiN
Default Motor Mounts
Hello again.
I am in the process of buying a new 3800 series 2 engine for my Camaro. Massey's swap thread has been a real help but I have a question which I think I know the answer to but wanted to verify.
If you buy a FWD engine, wouldn't you have to weld the motor mounts to accommodate a RWD setup?
Old Feb 10, 2013 | 04:16 AM
BasicConcepts's Avatar
Technical User
No the mounts line up but you have to run the RWD mounts. The RWD and FWD 3800 blocks are the same.
Old Feb 10, 2013 | 05:46 AM
why not use a series 3 engine, 20 more hp
Old Feb 10, 2013 | 06:51 AM
FBodyjunkie's Avatar
Probably wasn't aware of it Craby
Old Feb 10, 2013 | 08:06 AM
Edwardgp's Avatar
Did you already buy the series 2 or can you back out and get a series 3.
Old Feb 11, 2013 | 11:28 AM
PiN's Avatar
PiN
I haven't bought the engine yet but there is a significant difference in price in my area between the two engines ($400 vs $1000). IDK if 20hp is worth $600.
Also, don't you need different injectors and the whole setup for the series 3?
Old Feb 11, 2013 | 01:20 PM
gotta take the top end of your 3.8 and transfer, intake, rack, sensors etc, and from bottom need oil pan. series 2 is older so it would stand to reason that they would have more miles and time on em.
Old Feb 11, 2013 | 02:55 PM
fbodyrs96's Avatar
you can get a complete low mile L26 form ebay shipped for around $600, or so one of my friends did, twice. very bad luck with his engine builds.
Old Feb 11, 2013 | 07:00 PM
PiN's Avatar
PiN
Cool. What do you mean by rack?
Old Feb 11, 2013 | 07:33 PM
injector rack and injectors, may need oil pump, not sure if pickup is same but if pan is different pickup usally is, might get away with just changing oil pickup
