1980 Camaro wiring problems
Old May 21, 2010 | 12:46 PM
kyphur's Avatar
If there's no air going into the box from the broken area I think you're fine. The orange wire with the adapter on it looks like the electronic kickdown for a TH400 transmission or atleast that what mine looked like when I had it.
The black wire almost looks like a thick HEI tach wire. Not 100% sure on that as I think they were brown.
The two suggestions with wires that I just made are more guesses than actual knowledge. Without being there to trace them I couldn't be 100% sure.
Old May 21, 2010 | 06:09 PM
The "mystery box" in #8 is your AC unit.
Old May 21, 2010 | 06:34 PM
megamax42's Avatar
I didnt see any hoses or possible air channels through this protusion, thats what bothers me though. Its a pretty precise mold they had just so this odd thing will pop out, so I figure it has to do something....then again, it is gm.
Sorry I shouldve been more clear, mystery prtotrusion, not mystery box, but now I guess that gives me something to call it.
Old May 21, 2010 | 10:19 PM
kyphur's Avatar
If I can remember I'll pull my old box down out of storage and take a look at it tomorrow.
Old May 22, 2010 | 08:02 AM
rosky69's Avatar
I just went outside and looked at my ac box. There is a plastic protrusion on the right side(if your facing it). There's a vacuum operated ball thing bolted to it, but it (the protrusion) doesn't look like anything important. the ball thing could probably be bolted down somewhere else.
Old Nov 8, 2010 | 10:13 PM
fataltides's Avatar
Default It is supposed to be there
Not sure what you mean by the "mystery box". Inside is a part of the A/C system.
the mystery protrusion from the box is a drain. (supposed to be there). Inside the housing is the Evaporator for the A/C which produces large amounts of condensation and needs to drain the condensation. sometimes these have a hose attatched. I dont believe that is the case here.
Old Jul 16, 2011 | 04:00 PM
Z28cqmaro's Avatar
Mystery box is your heater core. I've seen it removed but you won't have heat or cold air
Old Jul 17, 2011 | 10:54 AM
fataltides's Avatar
It isnt the heater core...the heater core is inside under the right side of the dash, this is the A/C condenser.
Old Jul 17, 2011 | 12:09 PM
You guys do know this thread is almost a year old. I haven't seen Kyphur in a while
Younginwit67
Dec 21, 2013 09:07 AM
mgg4591
82-92 V8 Tech
Jan 31, 2012 09:00 PM
JGRAHAM
Oct 6, 2009 03:10 AM
BAN WS6
Jul 30, 2007 03:54 PM
xc|bandit
Mar 30, 2006 08:16 AM
