1971 RS/SS front springs
Old Mar 30, 2012 | 08:16 PM
ScottC1971RS/SS's Avatar
Default 1971 RS/SS front springs
I have a 1971 RS/SS that I bought lowered a little. I'm tired of walking it through bumps and ditches in the road. Can anyone tell me how the Camaro came from the factory? Some reference to a measurement somewhere about how far off the ground it should be front and rear. Also If you have recently replaced your front springs which ones did you use, Part #?. I want it close to factory height but I like the look of a little lower in the front. The springs on my car don't seem to absorb bumps, or rebound quickly, and let the car slam the pavement. The nose is 7.25" of the ground. I have just rebuilt the original motor and trans and put in a aluminum intake on a 350 motor so it doesn't have that weight under the hood. Will post a pict when site allows. Thank you
Scott
Old Apr 11, 2012 | 12:53 PM
Tommy13's Avatar
Scott
Wish I could help you with the factory measurements.That's something i'd like to know myself as well.
My Camaro was originally a 6cyl...so i'm assuming the springs on mine are only suited for a 6cyl. When I put my 350 in, it dropped the front end down a bit, but nothing that caused any problems.
I've since added different tires and rims, the tires being bigger. Even also swapping the manifold to the aluminum Edelbrock Performer, it didn't lift it up much more.
I used the $10 universal spring compressors, and reversed them to seperate the springs a bit so the tires wouldn't rub when I hit bumps.
I'm pretty sure Autozone sells OEM springs for the front. Don't think there's an in between when it comes to you wanting a lower look, but maybe someone else will know for sure otherwise.
As for adding pics.....you can get a photobucket account...upload your pics from your computer to their...and then you can copy image, and paste it in your replies..it will look like the pics I have.
AstoriaZ28
12
May 10, 2016 10:22 PM
ripigs
Jul 4, 2013 08:13 AM
playboy
Jul 7, 2010 03:24 PM
1971camaro_project
Jan 14, 2010 08:31 PM
1stgenssclone
Nov 27, 2007 06:26 AM
