What is thebiggest tires for 67 Camaro?
Old Feb 21, 2012 | 08:06 PM
cgcss1's Avatar
Default What is thebiggest tires for 67 Camaro?
Disc brakes in the front with drum and mono leaf in the rear.
I have 4 aftermarket wheels that are 16x8 with 4.75 backspacing. I do not believe I am going to be able to use these in the front from what I have read unless someone tells me something different. I do have 2 15x7 OEM rally wheels for the front if need be.
So what is the biggest size or at least a for sure safe bet for tire size?
It would be real nice if I could use the 16x8's on all fours so I can rotate all the tires.
Again, I have read that the biggest on the rear would be 245/50/16. If this is the case I see no reason why a 235/60/16 would not work. Have read that you need to relocate shocks which is something I am not going to do.
If someone can shine some light that would be great so I can order them asap and no I have no way to try different tires to see what would work. Just need to know what will work for sure and have had no luck finding a definite answer as there are so many different answers out there.
I am more concerned with height than width and want the car to stand tall as possible and I do not want to deal with rubbing of any kind whatsoever.
Thanks guys!
Old Feb 21, 2012 | 11:00 PM
1969 SS's Avatar
4.75" is going to be the wrong offset in front. That's pretty much as big as you want to go on those wheels. Just because a bigger tire will "fit" on an 8" wheel, doesn't mean it's the right thing to do
You probably could fit a 255 in the rear though, but every old car is different so you would really want to testfit before you bought the money
Old Apr 18, 2012 | 03:14 PM
CamaroJoe68's Avatar
Did you roll or clearance the inner fenders a bit? Im looking for the same thing widest tire on my '68 in the back. Subscribing to this thread...
Old Apr 23, 2012 | 03:01 PM
68CamaroSFL's Avatar
Default My Rims
I have a 68 Camaro with front disc brakes and rear drums brakes with mono leaf springs and I have:
18x8" front rims 4.5" backspace with 225/45/18 tires
18x9.5" rears 5" backspace with 275/40/18 tires.
Looks mean and only rubs a hair on the back with 4 people in the car
I had some special custom rotor spacers made from billet aluminum and used a different rotor so rims would tuck under and not rub.
That rim combo on the front usually sticks out a little.
Old Apr 25, 2012 | 06:02 PM
Thanks for sharing your wheel and tire combo 68CamaroSFL. Sounds like a nice setup you are running do you have a few photos of it? Seems like you have somewhere around the size I would want to run on my '68 since you only have minor rubbing with 4 people, good combo...
Vetteman61
Feb 3, 2011 07:29 AM
BasicConcepts
Mar 31, 2010 03:11 PM
diljosh
Feb 26, 2010 09:18 AM
jason7504
Nov 20, 2009 04:45 PM
