98 camaro tires
Old Feb 22, 2010 | 11:51 AM
diljosh's Avatar
Default 98 camaro tires
I have a 98 camaro base with 55 option rim, so my tire size is 235/55R16, I live in Iowa and get a ton of snow, so I was planning to put Bridgestone Blizzak WS60 tires, but they come only in 235/60R16 or 235/65R16. So can anyone tell me if I can mount these tires that have a taller sidewall. What will be the side effect of it. Thank you.
Old Feb 22, 2010 | 12:54 PM
reaper2702's Avatar
Default yes
i had 2256016's on my car. just took them off it will fit fine. im using them for winter tires now.
Old Feb 22, 2010 | 12:56 PM
evilkal's Avatar
They will fit but your speedo will be off slightly because of it. I'd go with 245/50 personally but whatever works for you.
Old Feb 22, 2010 | 02:46 PM
RFxCamaro's Avatar
the v6s 3.8 came with 215/60/16 stock so your actually fine
Old Feb 22, 2010 | 04:35 PM
evilkal's Avatar
Mine didn't ^_^
Old Feb 23, 2010 | 01:50 AM
RFxCamaro's Avatar
idk what to tell you the inside of my door jamb even said thats what they came with factory
Old Feb 23, 2010 | 06:26 AM
02StanGT's Avatar
Kal is just saying that not all 6er's came with that size tire. Besides 215/60/16 is actually shorter than the 235/55/16. Just because the second number is bigger, it doesn't always mean a taller sidewall.
Old Feb 23, 2010 | 06:30 AM
Dappled Apple's Avatar
yea mine came with 235/55/16 on her
Old Feb 23, 2010 | 01:05 PM
evilkal's Avatar
Mine came with 245/50
The base model got 215/60R16
The RS got 235/55R16
Then the Y87 RPO came with 245/50R16 tires along with other fun stuff.
Old Feb 24, 2010 | 02:33 AM
RFxCamaro's Avatar
mine is an rs, it even came with t-tops, i know that mine are thinner thats why i said he should be fine
