New design 68 RS Body Molding Clips
Old Aug 29, 2023 | 10:04 AM
kscheffy's Avatar
Default New design 68 RS Body Molding Clips
Body shop type question. A new molding clip is available for 1968 RS body moldings, which look much better than what has been available. They are push-in spring steel with a OEM style attachment to the molding. My issue is the Classic Template notes to check the clip for hole size, the clips do not specify, and the assembly manual notes a clip with a nut on the back, so I can't go by that. 5/16 dia fits nicely, but paint and primer will reduced the dia. and likely end up chipping the paint around the edges, or I could clearance the hole after painting. Either way you end up with bare steel exposed. A larger hole may end up with a sloppy fit and a loose molding.
Anyone have experience with this?
Old Feb 1, 2024 | 04:46 PM
joelle king's Avatar
what did you do about this matter ?
Old Feb 1, 2024 | 05:04 PM
kscheffy's Avatar
I went with the 5/16 hole. Car is getting painted next week. so I don't yet know the final word on how it will work...it will be a couple weeks before I mount the moldings. If I do need to clearance the holes, at least it is behind the trim.
peterklaassen2010@hotmail.com
West
Jun 3, 2020 11:00 PM
Jan 13, 2020 11:30 AM
ztwentyate
Jun 13, 2015 12:10 PM
jigoe007
South
Dec 1, 2013 07:22 PM
71CamaroZ28
May 25, 2009 04:34 PM
