wtf on engine
Old Jan 14, 2008 | 08:23 PM
69dmz's Avatar
Default wtf on engine
New 406 in the camaro. Installed a new MSD 6al, blaster 2 coil, and a new MSD pro billet distributor on the engine. The engine has been thru the break in process. It was sitting for a couple of weeks until I had the free time to install. I get fuel, spark, and the engine cranks over. Its not starting. WTF? Any help would be greatly appreciated.
Old Jan 14, 2008 | 09:33 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: wtf on engine
Are you certain the distributor is in right? If the engine has already been run, was that with the MSD unit?
Old Jan 14, 2008 | 10:25 PM
69dmz's Avatar
The distributor has not been touched or moved in any way. Installed the super conductor spark plug wires,wired upthe 6al Ignition, and new coil. I took out the old Msd 5200 and old coil.
Old Jan 14, 2008 | 10:38 PM
Ircyklops's Avatar
Try putting the old stuff back in and see if it runs. The coil or 6A box could be bad.I had a brand new defective MSD distributor that gave me fits and wouldn't fire. I put the old point distributor back in and it fired right up. I sent the MSD distributorin and they replaced the pick-up unit for a fee!
How about valve lash...maybe too tight? just a thought...
Old Jan 15, 2008 | 06:08 PM
69dmz's Avatar
Took a look at the wiring diagram in the Chilton manual. The ignition wire from the Msd was hooked up wrong. Fires up without any problems after fixing it.Now all I have to do is clean up the wires and weld in the new super 44's. Thanks..
Old Jan 16, 2008 | 08:34 AM
69dmz's Avatar
I still need to wire up the factory tachometer. How do I hook the muncie back up correctly. Its spinning when I start the engine. I don't have the chilton manual handy.
Old Jan 25, 2008 | 11:31 AM
69dmz's Avatar
Update.........Got the 6al hooked up. Flowmasters are in and sounds good. I bought a high torque starter to replace the old factory one. It runs fine but it is hard to start with the weaker starter.
Old Jan 25, 2008 | 12:35 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Well, that will happen. Good to hear you got it running.
Old Jan 26, 2008 | 09:01 AM
69dmz's Avatar
Thanks....should be getting my high torque starter on Monday.
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
