Tank sending unit
Old May 10, 2007 | 01:56 AM
bdam0214's Avatar
Default Tank sending unit
I have a 1969 rally sport with center console gauges. I replaced all wiring but can't figure out where to connect the tank sending unit in the rear. Any help would be great. Thanks.
Old Jun 8, 2007 | 09:01 PM
69RS350's Avatar
Default RE: Tank sending unit
On the top side of the tank there is a connector about the size of a ball point pen. I think the wire is blue
with a black rubber cover.
Old Jun 8, 2007 | 09:19 PM
69RS350's Avatar
Im not sure if this is where you meant you need to make a connection.
Old Jun 20, 2007 | 02:08 AM
bdam0214's Avatar
I'll check it out. Thanks.
Old Jul 13, 2007 | 03:08 AM
bdam0214's Avatar
Where does it connect to from the tank? I dont see any connections on the wire harness.
Old Jul 17, 2007 | 10:30 AM
jonnyNITRO's Avatar
I believe the wire you're looking for is in the wire harness. The cluster that runs along the driver's side channel under the door threshold trim. On the '67 it's a TAN wire. I don't know it they changed it for '69. Haven't done mine yet.
Old Dec 2, 2007 | 12:56 AM
markinhere's Avatar
i just did mine and it's a yellow wire on the wire harness at the rear of the trunk. It's a double connector and it plugs right in
mrlazar75
Apr 9, 2012 08:51 PM
CamZ28aro
Jul 2, 2007 12:36 PM
Danzig
Jun 6, 2007 02:16 PM
bdam0214
May 11, 2007 02:22 AM
89 Iroc Conv
82-92 V8 Tech
Mar 30, 2007 12:24 AM
