SMALL BLOCK QUESTION
Old Oct 30, 2007 | 07:24 PM
67classic's Avatar
Default SMALL BLOCK QUESTION
Is this a good start? Any advice or changes to improve power?
1970 350 HO Block, line honed, bored .30, hot tanked, magnet tested[/b]
4 bolt block and arp studded[/b]
New rotating assembly with TRW 9.5-1 pistons [/b]
New cranks and cams[/b]
Holley 650 Mechanical Carb[/b]
Ported and Polished Camelhump/Fuelie heads[/b]
Edelbrock Torker Intake Manifold[/b]
Roller rockers and lifters[/b]
Holley Bluepump with AN lines[/b]
Hooker Headers, 2.5 inch exhaust, magnaflow mufflers[/b]
Aprrox 9.8-1 CR[/b]
Est. 450TQ and 475HP[/b]
Old Nov 19, 2007 | 11:40 PM
Bob Jones's Avatar
Default RE: SMALL BLOCK QUESTION
Hi Need a bit more info on cam choice,trans and gears. Also how do you plan on driving it? street/strip? Idle quality? The pistons are flat tops i assume? Lots of choices for the SBC. Normally the torquer is not as good a choice as the RPM Air Gap but if you already own it then make it work. I am assuming pump gas is needed so that is why your low on compression. But you can have a heck of a good time with a nice torquey 350. Any flow figures on the heads?
ozzies 68
Mar 30, 2015 04:15 PM
tecumseh
Mar 8, 2011 01:01 PM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
rpdalton
Apr 12, 2006 03:45 PM
