Recommendation needed for big block replacement
Old Jan 4, 2016 | 09:53 AM
Gregt909's Avatar
Default Recommendation needed for big block replacement
I have a 68 camaro with a non numbers matching 396 and I'm thinking of replacing it with a crate 396. I already upgraded my 4 speed to an M22 with a steel mid plate and a new 12 bolt rearend. I'm would like to get 500hp. Is that doable with a 396 or should I look at a 427 or 454? I would like to keep it looking like a stock 396. Any suggestions on engines or builders?
Old Jan 4, 2016 | 10:31 AM
Everett#2390's Avatar
Look for a 454, but I'd stay with 427 - because of neutral/internal balance vs external balancing of 454 if revving.
Otherwise, 454 would do fine.
I would look at GM Performance for a crate engine, ZZ427 as example, because of good warranty (on all engines) and they have been ran and broke-in. Select your price.
Old Jan 5, 2016 | 06:07 AM
bruce69camaro's Avatar
500HP is doable, in 396. I have one in my car, but it is not a street car.
I use stock GM heads too and the only thing that looks aftermarket is the intake and carb.
I talked about putting mine back on the street and it could be done, but I'd have to run at least 110 octane fuel and that tends to get expensive....LOL
lwh
Jul 13, 2021 12:09 PM
Gregt909
Dec 31, 2013 04:40 AM
junojpeg
67-69 V8 Tech
Jul 21, 2008 06:58 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
1st_love
Aug 23, 2006 04:26 PM
