Dunno. I hadn't taken the gasket off the block. The gasket only had the ten holes in it. and I couldn't find a replacement gasket so I didn't want to remove it to check.
Well I hope it doesn't leak but it probably will,good luck with it.
Most of them have 18 holes,I couldn't even find a pan online with only 10,does your block only have 10 holes?
I actually stayed with the oil pan gasket (reusable) on the stroker. The oil pan not fitting was solved by using the big block motor mounts. And even with 10 oil pan bolts there have been no oil leaks.
