Sealing oil pan
Old Jan 16, 2019 | 02:05 PM
Robert Kendall's Avatar
Default Sealing oil pan
Tore my 327 down to replace seals, fix leaks, clean and paint. During reassembly, I used RTV on both sides of the oil pan gasket. The rubber arched pieces on the end, I RTVed between the block and the seal but not between the seal and pan. Is this a problem? And if I remove the pan to reseal it, to I need new gaskets? Finishing the intake and valve covers this weekend.
Old Jan 16, 2019 | 04:58 PM
Zspoiler's Avatar
I have a 1979 Z-28 with a supercharged small block .And I used a Fel Pro one piece oil pan gasket with a little dab of RTV,With no issues. The tech is out there might as well use it
Old Jan 17, 2019 | 07:26 AM
cool, didn't know that was available. I was hoping someone would tell me I didn't have to drop the pan, but I sorta knew that wasn't the case. Since I'll need a new gasket anyway, maybe I'll look for that.
Old Feb 7, 2019 | 03:29 PM
Bought the Felpro rubber gasket. What a difference! miles better than the original multi-piece cork one. Good call!
Old Feb 7, 2019 | 07:34 PM
Only way to fly!
GoofieJ21
Aug 5, 2023 02:30 PM
Connerj1996
Mar 28, 2013 02:44 PM
pcarollo
Jun 13, 2012 11:08 PM
husker_camaro95
Feb 8, 2011 04:16 PM
TEXASMAN1
Oct 1, 2008 12:53 PM
