Location of water temp sensor
Old May 27, 2016 | 09:12 AM
Robert Kendall's Avatar
Default Location of water temp sensor
Recently purchased a 68 with 327. Car has no coolant temp sensor, not even a dummy light. I want to install one, but not sure where it attaches. Any help?
Old May 27, 2016 | 09:47 AM
Drivers side head, between exhaust ports. If not a sending unit there, there would be a plug.
Although that's the "factory" location, I have a different outlook and prefer it to be in the intake manifold. Because of radiant heat from the exhaust manifold/headers, and the nature of the beast where the heads are the hottest part of the engine, the head location will read hotter than what the overall engine temperature actually is. Sending unit in the head reads head temperature, in the intake manifold is more realistic to reading the actual temperature of the coolant that's flowing through the engine.
Take it for what it's worth, depends on what you want to monitor.
Old May 27, 2016 | 12:09 PM
Everett#2390's Avatar
Check instrument cluster for missing/removed TEMP light bulb.
Correct as to 69 suggests and the cylinder head would be where the thermal switch is located.
TEMP light gets a bulb check when ign switch is in START position - TEMP light should come on.
Look for a light green wire in engine harness - ground the lead and light should be lit.
Old May 30, 2016 | 04:46 AM
Thanks for the info. I will check it out. Makes me REALLY nervous driving without temp indication.
Old May 30, 2016 | 04:49 AM
Thanks. When the key is turned on, all I get is a GEN light. I suspect a bunch of little problems in the dash, as the radio is inop, and the light in the footwell stays on. Oh well, it gives me an excuse to hang out in the garage
Old May 30, 2016 | 08:05 AM
Also, with key on, engine off, OIL light should be lit as well as GEN light
sm515
Apr 27, 2014 01:27 PM
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
kyleag89
Oct 5, 2008 12:18 AM
blueeyes3333
Sep 25, 2007 03:04 PM
randscr
Sep 13, 2006 12:32 AM
