Location of water temp sensor
Recently purchased a 68 with 327. Car has no coolant temp sensor, not even a dummy light. I want to install one, but not sure where it attaches. Any help?
Drivers side head, between exhaust ports. If not a sending unit there, there would be a plug.
Although that's the "factory" location, I have a different outlook and prefer it to be in the intake manifold. Because of radiant heat from the exhaust manifold/headers, and the nature of the beast where the heads are the hottest part of the engine, the head location will read hotter than what the overall engine temperature actually is. Sending unit in the head reads head temperature, in the intake manifold is more realistic to reading the actual temperature of the coolant that's flowing through the engine. Take it for what it's worth, depends on what you want to monitor. |
Check instrument cluster for missing/removed TEMP light bulb.
Correct as to 69 suggests and the cylinder head would be where the thermal switch is located. TEMP light gets a bulb check when ign switch is in START position - TEMP light should come on. Look for a light green wire in engine harness - ground the lead and light should be lit. |
(Post 711320)
(Post 711327)
Also, with key on, engine off, OIL light should be lit as well as GEN light
