fuel gauge troubles
I just purchased a new autometer colbalt c2 fuel gauge to go into my new console with the 4 gauge 2 1/16 " mounting. I will wire it dierctly to fuel sender and discounect the one in the dash and leave it in place unti i find a tic toc to replace the original fuel gauge. I do belive i either have a intermitting bad ground or sender wire problem because it works intermittingly.
Its been a few months since the last post in this thread, but I just had the same thing happen to my gas gauge tonight. Its at a 3 o'clock position with the key on, however when the key is turned off the needle does go back down like it wants to function. The needle ranges from between 2 and 3 o'clock.
When i lower my fuel tank i found the ground wire coming from the sending unit just barely hanging on. That was my problem , just replaced the whole sending unit after 44 years it was time !!!!
i have a 93 camaro and was checking out why my gas gauge will not work it shows over full under the car i have found a black wire with a white line down it and cant find out where it goes any ideas the wire comes directly from the gas tank
Great information and knowledge
Hello every one. I just joined this site. I just want to say, Wow! All the great information on here is wonderful. A lot of my issues with my '67 Camaro SS have been covered, and I felt great with other issues that I worked out my self have also been covered. So thank you for your kind and thoughtful messages I have read. I wish I could have found this site last week as I was working on throttle issues. I'm going to dig in and start working on all the awesome info I learned yesterday, so thank you gentlemen. If I can help, I will. Take care
