Driver door will not unlock
I have a 68 Camaro, virtually rust free from Phoenix. My problem is the door on the drivers side will not open as if the lock is stuck. When I compare it to Pax side the outside plunger feels identical to the other when the lock is engaged.
I can not open it from the inside either. Car did sit for a while so it might be stuck but I have had no luck getting it to open.
Frustration is sitting in, any help would be appreciated.
Thanks,
Coldtexan
Thanks,
Coldtexan
Weeha
08-10-2011 07:00 PM
