corrosion problem on 69 camaro
Old Mar 12, 2008 | 10:42 AM
scottlee1's Avatar
Default corrosion problem on 69 camaro
i have a unique problem. Since ive repainted my block and put new bolts in i've got a problem with corrosion. Not rust corrosion but white scale. It is forming on bolts that are not zinc coated or stainless. I though maybe a grounding issue, so i checked the block ground and cleaned it again and regrounded. still scale seems to form, almost as if it were on the coast line in the salt air, but i leave 80-90 miles from the nearest coast line. I really didnt want to soak my engine in wd-40 to stop corrosion, Does anybody have any ideas on what to do or what may be causing this problem?
thanks scott
Old Mar 12, 2008 | 03:51 PM
Default RE: corrosion problem on 69 camaro
Which bolts are you talking about, and are they bare or painted? It sounds like you're describing a dielectric issue. You can get a build up of corrosion when you attach two dissimilar metals together, where there is a presence of electrolysis (such as internal flowing water), and also where there is a conductive path (ground). For instance, in home plumbing, if you were to attach a copper pipe directly to a galvanized pipe fitting, you will get a white crusty corrosion build-up where the two join. And, the house's plumbing pipes are also used as ground for the incoming power supply. In that case, you need to use a dielectric union which insulates the two from each other. Why you're getting it, I don't know. Is it possibly on your water neck bolts? I would think that using fiber washers as an insulator will most likely alleviate the problem.
libertyforall1776
Feb 24, 2014 02:11 PM
94Pepper
Dec 5, 2011 03:07 PM
92CamaroGuy
Oct 12, 2011 02:39 PM
ChevyManCam
Nov 26, 2010 08:44 PM
hendogg1114
LS Series Tech
Jul 14, 2009 09:24 PM
