383 Stroker Timing Question
Old 03-31-2013 | 07:38 PM
68Ride's Avatar
Default 383 Stroker Timing Question
I've got a 383 stroker in the 68 that I recently purchased. Today was the first day I've had a chance to road test it and there is some hesitation/bog just off idle and seems to be missing or very underpowered under acceleration.
I know it could be several things but I wanted to check the timing and realized that there is no timing pointer to reference the notch on the harmonic balancer.
What are the best options for checking and or adjusting the timing?
Old 03-31-2013 | 09:54 PM
YAV8's Avatar
Get the bolt on timing tab for a 8 inch balancher and go from their.
Old 04-01-2013 | 09:14 AM
68Ride's Avatar
Thanks. Simple enough. I didn't realize they were that universal. Any thoughts on where the initial timing should be set? All I know about the engine is that it was originally a 350 4 bolt from a 70's truck before being stroked. 40 over, 202 valves, roller rockers and an Edelbrock 750.
Old 04-01-2013 | 10:51 AM
Hard to say what timing should be without cam specs. Once you get the timing tab installed you can start playing with timing settings and advance it until it runs well. After you get it running better, then shut it off and see how it restarts when warmed up. If it starts hard back the timing off slightly until it warm starts easily. Then if it drives well, starts warm easily, check the timing with a light and record it for future tuning.
glue maker
05-19-2010 02:27 PM
xxRONNIExx
06-23-2009 04:41 PM
FearThisInc
10-17-2008 09:27 PM
hillius31
04-19-2008 01:23 AM
trotro
82-92 V8 Tech
10-23-2007 02:21 PM
Quick Reply: 383 Stroker Timing Question
