350 engine doesn't have a fuel pump for my 68 Camaro
Old Nov 24, 2012 | 11:27 AM
dizzee03's Avatar
Default 350 engine doesn't have a fuel pump for my 68 Camaro
Hi Guys,
I need some advice from the pros out there. My ride has an I6 (originally had a V8) with a Powerglide Tranny and I just got a 350 5.7L from a 92 Chevy van which I intend to rebuild. However, I just noticed that there is no place to connect the fuel pump on it as that hole is sealed on the engine.
Is there a way to connect the fuel pump another way? If so, can anyone recommend a model or part number that they have had good experience with for a 68?
Thanks everyone!
Old Nov 24, 2012 | 12:00 PM
cad's Avatar
cad
You will need to run an electric fuel pump on that if there is no provision for the mechanical pump.
Holley 12-801-1 Holley Electric Fuel Pumps
A holley pump like this requires no additional regulator to maintain the 6-7 lbs of pressure that a standard carb requires.
You can get 3/8 pipe thread to barb fittings for the pump itself, and run rubber hose in and out. Power it only when the key is on.
http://www.jegs.com/i/Moroso/710/65380/10002/-1
Clark
Old Nov 26, 2012 | 07:19 AM
dizzee03's Avatar
Awesome! Thx!
Old Nov 26, 2012 | 07:57 PM
Everett#2390's Avatar
Use a relay, ign controlled, and run 14 AWG wire with an inline fuse, 10 amp, to the pump.
Then ground the other pump lead to a mounting bolt.
This power method will tranfer pump current through the relay contacts rather than through the ign sw and provide a pump off with the ign.
Somwe even run relay power through an oil pressure switch/sender to kill pump power in case loss of oil pressure.
Old Nov 27, 2012 | 04:14 PM
dizzee03's Avatar
Thanks for the info. So aside from the electric fuel pump I would also need the relay and the fuel pump safety switch.
I found these two link below on Jegs.
JEGS Performance Products 10564 JEGS Electric Fuel Pump Harness and Relay Kit
Holley 12-810 Holley Fuel Pump Safety Switch
Is this right or am I missing something?
Old Feb 11, 2013 | 02:42 PM
dizzee03's Avatar
Hi Everyone,
I have used the forum search to answer my dumb question and since I couldn't find the answer I'm going to ask my dumb question on here (please keep laughter to a minimum :-)
I'm rebuilding the 350 engine I have that came from a 92 Chevy G20 Van. This weekend I noticed that one of the exhaust manifolds is damaged and likely not usable. I was told that whenever I search for any parts that will connect to the engine to reference that the motor is from a 92 Chevy Van. However, when I looked up the part # for the van and compared it to the Camaro the part numbers were different (go figure :-). I'm assuming that means I have to replace both exhaust manifolds.
Is that accurate? Should I be looking for 68 Camaro manifolds or will the 92 Chevy Van manifolds fit?
Or is this one of those things that will purely be trial and error until I find what fits.
Thx everyone!
Old Feb 11, 2013 | 08:12 PM
YAV8's Avatar
I would put on a set of headers long tube or shortys or block huggers. More power and problem solved.
Old Feb 12, 2013 | 12:11 AM
A gen 1 small block is a gen 1 small block. You're looking for exhaust manifolds or headers that are made to fit your car.
Old Feb 19, 2013 | 03:43 PM
dizzee03's Avatar
Cool thanks for the responses.
I'm considering a kit I found on Summit Racing website which includes long-tube headers, mufflers. The kit is sku # is SUM-CBJJ200.
Summit Racing® Dual Exhaust Systems SUM-CBJJ200 - SummitRacing.com
According to their website it should fit my car.
I'm curious if anyone has had any experience with this kit.
Also, does anyone know if my car would require a catalytic converter to pass inspection in Texas.
Thanks
mloaks
Nov 23, 2011 01:42 PM
samtron
Oct 1, 2009 11:32 AM
99Z28
82-92 V6 Tech
Apr 13, 2007 12:45 AM
chevyman81
Dec 19, 2006 05:48 PM
