TH400 speedo housing leak
Old Jun 30, 2012 | 07:43 AM
Viking's Avatar
Default TH400 speedo housing leak
Hi,
1. my TH400 has started to leak around the speedo gear housing, i noticed that the housing says "36,37,38,39" while my green plastic gear has 42 teeths? That cant be right?
2. I will replace the housing because the hole at the end is quite oblong, may that contribute to the leakage?
3. Can i buy new housing for 40-45 teeths or do i need one similar to the one i got?
4. Also the shaft does not have a screw-shape, like i can see on other gear shafts on the web, is that important?
5. Can i replace the 42 teeth gear, without replacing anything else inside the case?
6. Where is the best place to buy trans parts on the web? I live in Norway, has to be shipped.
Best regards, Kristian
Old Jun 30, 2012 | 07:59 AM
Viking's Avatar
JoeKramer
Mar 23, 2011 07:12 AM
ScottD
Oct 12, 2010 07:18 PM
383Stro
Apr 23, 2010 11:06 AM
ScottD
Jan 4, 2009 09:45 AM
Andross
Nov 7, 2006 06:59 PM
