TH350 adjustment
Old Oct 4, 2020 | 04:17 PM
Eric Sabatier's Avatar
Default TH350 adjustment
I am about to change the oil in the TH350 gearbox as I have no idea when it was changed. Oil seems to be nice and recent but I prefer to open it and put new oil in.
I will check the filter while it'll be open.
This car has no kick down. When you press the pedal to the floor there is no down gear change. Is it supposed to have a kickdown or is it optionnal?
How can I tell? I don't know what to check.
Also while it will be open is there any adjustment to the band to make or check? What is the procedure there?
Old Oct 5, 2020 | 06:51 PM
Everett#2390's Avatar
Yes, kickdown linkage at carb is standard equipment. There should be a cable hooking to a ball stud on carb linkage below pedal linkage.
This same cable will have its own bracket on intake manifold for adjustment and holding cable.
Inside trans pan, cable will hook to a lever, spring loaded lever.
If no cable at trans case, next to fill tube, there will be a heck of an oil leak.
Old May 23, 2023 | 05:55 PM
MrAngry's Avatar
Default the kickdown cable is more important than people think.
On the th350 it controls the throttle valve that raises line pressure when the throttle is depressed all the way. If you have a 700r4 & don't hook up the cable, it will mess up the trans, as on that unit it controls shift points too.
Old May 23, 2023 | 06:51 PM
Hey Mr Angry great to see another 1st gen guy! try to keep an eye on the dates on the posts you reply to. I do thank you for supporting the sight and look forward to seeing your post in the future.
Old Dec 27, 2024 | 03:35 AM
No problem replying to old posts.
The gearbox has not been worked on yet !!!
I hope to be able to work on it in 2025...
kulrajg
Aug 17, 2017 04:45 PM
v64thgen
Apr 23, 2014 10:25 AM
BoricuaHec01
LS Series Tech
11
Mar 16, 2011 08:15 AM
H2C
Dec 14, 2010 01:58 PM
SYDEWAYZSS
Oct 19, 2007 07:24 PM
