Locker Rear Differential
Old Sep 25, 2018 | 11:40 AM
DLC99's Avatar
Default Locker Rear Differential
I'm new to this all and was looking for some help or information on locker differentials. I bought a 1968 Camaro and the guy said it has a locker rear end. I'm not sure what kind, but it has an alum cover with SS on it.
My questions are:
1. Can anyone tell what it is or who the manuf is?
2. Can this rear end be used for road course driving?
3. Would this type rear end cause one rear tire to lock up early before the other tires, on heavy braking situations?
Thanks for any help you can.
Dar
Old Sep 25, 2018 | 12:11 PM
flat tire's Avatar
Locking differential
From Wikipedia, the free encyclopedia
Jump to navigation
Jump to search
A locking differential is designed to overcome the chief limitation of a standard open differential by essentially "locking" both wheels on an axle together as if on a common shaft. This forces both wheels to turn in unison, regardless of the traction (or lack thereof) available to either wheel individually.
When the differential is unlocked (open differential), it allows each wheel to rotate at different speeds (such as when negotiating a turn), thus avoiding tire scuffing. An open (or unlocked) differential always provides the same torque (rotational force) to each of the two wheels, on that axle. So although the wheels can rotate at different speeds, they apply the same rotational force, even if one is entirely stationary, and the other spinning. (Equal torque, unequal rotational speed).
By contrast, a locked differential forces both left and right wheels on the same axle to rotate at the same speed under nearly all circumstances, without regard to tractional differences seen at either wheel. Therefore, each wheel can apply as much rotational force as the traction under it will allow, and the torques on each side-shaft will be unequal. (Unequal torque, equal rotational speeds). Exceptions apply to automatic lockers, discussed below.
A locked differential can provide a significant traction advantage over an open differential, but only when the traction under each wheel differs significantly.
All the above comments apply to central differentials as well as to those in each axle: full-time four-wheel-drive (often called "All Wheel Drive") vehicles have three differentials, one in each axle, and a central one between the front and rear axles (transfer case).
Old Sep 25, 2018 | 02:54 PM
Zspoiler's Avatar
A locker rear end is more for drag racing than road racing .and on the street ,Because it has no "give" like a regular posi .
Old Sep 25, 2018 | 07:25 PM
A "locker" is a locking differential which is also referred to as a "posi" or limited slip. Zspoiler is referring to a "spool" which ties both wheels together solid, and has no differential. Totally different animal. The only way to know just what type of diff you have is to remove the cover and explore.
Oh, and the SS on the rear cover, is it two distinct S's, or a funky looking sort of double S logo? If the latter, that's Strange Engineering. But, the cover says nothing about what may be inside.
Old Sep 26, 2018 | 11:26 AM
I am with Zspoiler on this one. A locker is for drag racing and serious 4wd while limited slip or Posi traction is for a road course.
https://www.chevyhardcore.com/tech-s...differentials/
Jason Stockton
Mar 5, 2012 02:08 AM
sinfulrs
82-92 V6 Tech
Dec 5, 2009 07:28 PM
BojanglesBatman
Sep 24, 2009 07:29 AM
Kev79
Jun 18, 2008 09:37 AM
olemart
Mar 4, 2006 01:05 AM
