gear swapping help
Old Feb 20, 2012 | 07:22 PM
Dcapper81's Avatar
Default gear swapping help
Hello. I have a t10 4 speed thaat needs to be rebuilt. I want a 5 speed but I simply can't afford that right now. I reaally want that overdrive gear though. I was wondering if it was possible to swap 4th gear to an overdriven gear somewhere around .8 or .7 instead of 1:1? Has aanyone ever heard about or done this? And if so is it expensive?
Old Feb 20, 2012 | 11:29 PM
Dcapper81's Avatar
Does this just sound completely rediculous?
Old Feb 21, 2012 | 10:22 AM
No can do without a complete redesign. Keep in mind that 4th is direct drive, where the input shaft is locked to the output shaft. To change 4th to overdrive will require additional gears inside the case. What you could do, is add an overdrive unit outside of the case such as the ones sold by Gear Vendors.
GM Manual Transmissions | Gear Vendor Overdrive | GMC 2-Wheel Drive Manual Transmission | SM465, SM4 - Drivetrain.com
Old Feb 21, 2012 | 11:36 AM
Dcapper81's Avatar
Thanks. I didn't know that. The gear vendors overdrive would be sweet, but it cost just about as much as a full tko500 kit :/ if I still decided to have the gear swapped, how much woul you guess it would cost? I've got about $1000 to work with.
3.4putter
Jan 28, 2012 07:35 PM
EJHeavey
Feb 15, 2011 06:01 PM
97camaro89
Jul 16, 2010 10:13 PM
ccamaro88
Jan 4, 2010 12:06 AM
xdarkstar22x
82-92 V6 Tech
Aug 14, 2009 06:08 PM
