69 gear ratio opinion?
Old Aug 31, 2012 | 09:04 AM
Jrebyank's Avatar
Default 69 gear ratio opinion?
I have a 454 with 049 heads and a nice cam in front of a close ratio sag. Here's the deal, the sag will be coming out at some point but I have to use it at the moment. I am running a 8.5 10 bolt and was wondering what you guys thought would be a good gear ratio to go with. There will be a Muncie going in the car at some point that is for sure. So I'm intending on setting the rear end up as if I had it now. Any help would be appreciated!
Old Aug 31, 2012 | 04:13 PM
77thor's Avatar
I would go with a 3.55 or so.
Old Sep 1, 2012 | 08:08 AM
Both trans have the same final ratio, so the gearing wont change with either. I'm running a 3.42 behind my big block, and I really like the ratio. Don't really need much lower with the torque you'll have available.
Old Sep 1, 2012 | 07:11 PM
Y2K's Avatar
Y2K
Talking
4.56's!......
95 camaro 406
21
Jun 29, 2015 10:46 AM
Chaotic94
Aug 28, 2012 03:25 PM
savage02
LS Series Tech
May 30, 2010 09:55 PM
pureadrenaline
Sep 26, 2008 09:05 PM
jdubs1813
Apr 27, 2007 02:50 AM
