'67 Camaro Transmission Problem
Old Feb 24, 2009 | 05:40 PM
Sixty7 Camaro's Avatar
Default '67 Camaro Transmission Problem
1967 Camaro, 454 roller motor, 8.5" 10 bolt rear with 3.73 gears. I rebuilt the trans two years ago with PATC internals, h.d. clutches, upgraded intermediate sprag, oversize low/reverse roller clutch, new pump, etc. I was tuning the car and making great power so I decided to test it. Launched at around 3500 r.p.m. and everything was fine until I slowed down. No first gear! Second and third seem ok as does reverse. Any advice or suggestions? Thanks!
Old Feb 24, 2009 | 08:26 PM
bowtiemike's Avatar
sounds like a check ball in the valve body is stuck.
Eddie Cotter
Oct 11, 2014 09:43 AM
guitarranger11
70-81 Transmission & Differential
Sep 21, 2011 01:14 AM
BoricuaHec01
Oct 30, 2010 01:09 PM
bobbyjcardona
Jun 23, 2007 02:04 PM
scottlarocco
Oct 24, 2006 10:02 PM
