1969 Rs automatic to manual conversion
Old Feb 26, 2024 | 10:31 AM
Nice way to spend 20K. Real Nice. Going to need a stronger rear and rear suspension. they bunny hopped with the 375 hp big blocks.
Old Feb 26, 2024 | 02:17 PM
You may need to raise the whole trans tunnel. The magnum is bigger then the old school T56. You will not know how much until you set the drive line angles.
Old Feb 26, 2024 | 08:08 PM
Chrisheiges's Avatar
I messed up the guys talked me into the ls3 kit but I don’t want the 6.2 I want the 6.0 so that’ll be only difference. Still doing the connect and cruise just different motor
Old Feb 28, 2024 | 03:25 PM
I do not see the LS2 6.0 as still available on Chevy's Site. When I look at LS crate motors it starts at the LS3. In fact LS3 is all I see. I guess GM assumes if you where thinking LS7 then you should just step up to the LT motors. If you can find it the first thing you want to look at is the trans. Depending on the model transmission you may need major floor work. Also post a link.
https://www.gmperformancemotor.com/category/LSMAN.html
I am always budget minded, while I was looking at Pace Performance (a GM dealer) I saw a GM GEN 1 350 with throttle body efi and a TKX 5 Speed manual Connect and cruise. It was only 355 HP but it came with a 2 year 50K miles GM warranty parts and Labor. It was under $13,000. Also the TKX 5 speed does not require floor cutting at all in my 4 speed car. It is a top loading transmission so you may be able to just use a 2-3 inch hole saw on a auto car. I don't mind a LS or LT swap but I like the old school look. The motor comes with all the shinny parts but it seem like you could make it look stock without too much trouble. I am normally a build it myself guy but that is a lot of ordering parts and getting the wrong parts, reordering and if I was going to travel that warranty would give me a little more confidence If I had a problem I can just get the car towed to the nearest GM dealer.
zman69
Jan 26, 2020 03:03 PM
Rebuilt57
May 30, 2016 09:03 PM
Mr.Fitzkee
Mar 19, 2011 05:10 PM
bobyo
Jun 20, 2009 08:43 PM
burninrubber11
Jun 25, 2007 10:14 PM
