1967 Muncie 4-speed shifter handle
I'm collecting parts to finish the installation of my 4-speed Muncie into my '67 with a 327 SB. I'm going with the original Muncie shifter (I know everyone says use a Hurst Competition Plus). I've seen two different Muncie shifter levers/handles, both with Muncie engraved on the arm., both claiming to be for a 1967 Camaro. The difference is in what I'll call the offset from the mounting bracket that bolts to the transmission crossmember. One of the handles has about a 2 & 3/4" offset, the other has about 1 and 1/2" offset. I imagine when I actually install the assembly, it might be obvious which one will line up, but in the meantime I'm wondering which is the correct lever. Anyone out there help? Thanks again!
Going from memory when I looked into getting an original shifter 3 or so years ago. I believe there are with console and without console versions. The console version is marked console. I also believe there may be a Z28 shift handle but that would be out of a 68 .
