Spring compressor search
Old Mar 12, 2018 | 12:49 PM
planetaryslider's Avatar
Default Spring compressor search
I'm replacing control arm bushings & ball joints on my 69 & having trouble finding a spring compressor that fits. Any help will be greatly appreciated! Thanks.
Old Mar 12, 2018 | 05:34 PM
Everett#2390's Avatar
I have used this compressor:
https://www.harborfreight.com/single...sor-43753.html
Most auto p[arts stores will rent them, plus United Rental, or any tool rental shop.
Old Mar 12, 2018 | 10:22 PM
Al Loyrat's Avatar
Mine is a K-D 2528. Here is the best part: Made in the USA. Great welds and quality steel. Don't use power tools on it!
Old Apr 13, 2018 | 06:30 AM
arocars's Avatar
Another way to remove the spring. Get the car off the ground and on jack stands. Remove the shock. Put a chain through the spring for safety. Put a floor jack on the underneath backside of the lower control arm. Remove the inward lower control arm bolts. Slowly let the jack down. The ball joints will hold the front of the assembly together and act as a pivot point. Remove the spring from the back. Reverse the procedure to put the spring back in.
There's probably a u-tube video on this someplace.
Old Jun 7, 2018 | 10:20 AM
MikeJ67's Avatar
That is a sweet unit from HF - I'm doing my '67 now and used a standard unit. I had the shocks pulled (since I'm doing upper & lower control arms & springs) and ran the bolt up the center with the lower spring mount as close to the bottom as I could - the top of the bolt went thru the shock mount hole, I raised the control arm (& spring) up as high as it would go, then tightened the upper mount (on top of the frame) and let the jack back down. Popped off the lower control arm and then lowered the spring out. =)
QwietStorm03
Jun 28, 2018 07:49 AM
John 69 Camaro
Feb 28, 2016 05:33 PM
1977Camaro350
Apr 12, 2010 07:49 PM
buckmaster
Oct 30, 2007 08:17 PM
sewerrat
Jul 31, 2006 03:39 AM
