ride tech front shocks
Old May 27, 2019 | 06:57 PM
Bad rat's Avatar
Default ride tech front shocks
Hi guys , im running a big block in my 69 with the Ridetech coil over shocks and big block spring. the problem that im having is the springs wont support the weight of the car. I have aluminum heads and intake with a battery delete. Anyone else come across this issue? thanks.
Old May 27, 2019 | 07:13 PM
Lowering springs or stock height? Wrong size shocks or springs maybe? Something isn't right,I put a big block in my old '69 many years back and all I changed was the motor mounts and headers. Had iron heads too and I had no problems with it not holding the weight.
Old May 27, 2019 | 07:37 PM
Bad rat's Avatar
Not sure if its called a lowering spring or not. but I agree something isn't right
Old May 27, 2019 | 09:37 PM
Are you referring to the spring on the shock or the car's suspension coil springs?
If you have stock springs up front they may just be shot and need replacing,I ran stock springs in mine switching to a big block but if I were to replace them I'd order big block springs. Mine weren't all that old having done the swap when the car was only 8 years old.
Old May 27, 2019 | 11:31 PM
Bad rat's Avatar
The spring on the shock .
Old May 28, 2019 | 07:12 AM
Well I think I'd take it to a good front end shop then and find out why it's not holding up.
Old Jun 1, 2019 | 08:18 AM
Have you tried calling Ridetech yet? The weight of a big block with aluminum heads and intake is dang near the same as an all iron small block. When you say the springs won't support it, are the bottom adjusters cranked as high as they will go? Is the car bottoming out, or just not at the height you want it to be at?
Old Jun 1, 2019 | 03:15 PM
Bad rat's Avatar
Yes there sending me a spanner wrench. I was only hand tight. Thanks
wlbuckles
Jan 8, 2019 01:31 PM
surfhppy
Jul 15, 2012 09:40 PM
kudnu89
Jan 5, 2011 09:42 PM
MS69 YENKO/4-SPEED
Sep 14, 2010 08:57 PM
danny67
Nov 19, 2006 01:09 PM
