Lower ball joint loose?
Old Apr 1, 2018 | 06:29 AM
Robert Kendall's Avatar
Default Lower ball joint loose?
Replaced all the bushings and ball joints on upper and lower control arms, Base 68 convertible. I needed to press the ball joints out. When replacing them, one needed to be pressed in, and the other was snug but loose enough that I could press it in by hand.
When I test-drove the car, it was all over the road, very difficult to drive in a straight line.
Could this be the issue? I have never replaced one before, so I assumed it was kept in place by the spring tension from the coil spring.
xlman
Apr 22, 2011 10:18 PM
Packfan88
Sep 19, 2010 11:48 AM
bezerker
May 9, 2008 01:31 AM
73 T Top
Apr 25, 2008 03:46 PM
leadfoot55
Jan 19, 2006 09:59 PM
