Engine weight
Old Apr 28, 2013 | 09:06 PM
TJTIGER's Avatar
Default Engine weight
Hey guys fairly new here. Joined few years back and just haven't been active ont
The car for awhile. I putnqa1 coil overs with big block spring rait for my 396. I'm considering a new ls3 which is over 200 pounds lighter. What's the effect the heavier spring rate is going to have? I have hotchkis upper and lower control arms withn2" drop spindles too if that matters. Thanks. Garry
Old May 10, 2013 | 08:55 AM
The effect will be the car will sit higher, and have a firmer ride after you do the swap. If the QA1's are adjustable you can take some of that out with adjustment on the coils, but you may end up swapping springs if it's to firm a ride.
refderek
Dec 5, 2012 04:35 AM
libertyforall1776
Jan 13, 2012 09:58 PM
cambonesian
82-92 V8 Tech
Oct 26, 2007 07:10 PM
My01Z28
LS Series Tech
Oct 25, 2007 04:08 PM
