1968 firebird .. rear end seems off-center!
Old Feb 22, 2008 | 03:13 AM
knafel's Avatar
Default 1968 firebird .. rear end seems off-center!
Hi guys,
I was measuring the rear fenderwell clearances on my 1968 firebird to decide for a wheel spacer and noticed that the right wheel sticks out about an inch more towards the fender lip than the left wheel. Also noticed that the right wheel is sitting an inch more towards the rear of the vehicle and the left wheel more towards the front... Has anyone heard of a such misalignment situation? It could just be the rear fender sheet metal, but I don't think so, this used to be a straight car, no sign of accidents or anything. When the snow is gone, I will pull the car on a lift and take measurements from underneath. Until then, does anyone have an idea? Could this just be standard tolerances? I know this is not a camaro, but it's the same body, I thought you guys could help me out.
* I have 255/50/ZR16 tires and 16" AR TT2 wheels, both with same width and backspacing, nothing wrong there.
* Standard rear drum brakes
* Hotchkis sport leaf springs (about 1.5"-2" drop)
* Bilstein shocks
* Hotchkis rear sway bar[/align]* No traction bars installed[/align]
Old Feb 23, 2008 | 03:31 PM
JRs72RS's Avatar
February 2009 ROTM
Default RE: 1968 firebird .. rear end seems off-center!
You may be just seeing a difference in the quarter panels. If someone replaced them it is very posssible they are not exactly the same. Before jumping the gun on any repairs or mods take measurements from the centerline of the car or use the frame raiils as a reference point. Has the diferential been replaced? I have seen where people have put coil rear end in leaf car and welded the perch mounts off center.
Old Feb 23, 2008 | 10:42 PM
68streetfreak's Avatar
if you measure from the center point of the front wheel to the center point of the rear wheel both sides should be equal length, and using the center line to measure to the inside which should be equal length aswell hope this helps do you find your car pulls to one side ?
Old Feb 25, 2008 | 10:09 AM
1969 SS's Avatar
ORIGINAL: JRs72RS
absolutely all good points andsemi-common possible things to look at
Old May 4, 2008 | 03:08 PM
t9ojetpilot's Avatar
[&:] these may be mere differences in assembly or could be from past wrecks or saggy body to frame connections among other things. from the factory the novas of that vintage had nearly an inch difference on the left and right fenderwell clearance, just the way it was! the f body's may have had the same situation. a few measurements and a four wheel alignment should tell you if the car is heading straight down the road or has a twist in it somewhere and adjustments will have to be made from there kurt
Old May 5, 2008 | 05:01 PM
arocars's Avatar
I had a 78 Camaro with the same problem. The rear-end was original and the car had never been hit. The d/s rear wheel was an inch closer to the fender lip than was the p/s rear wheel. I never did anything with it. I figured it was probably within factory tolerance.
Old May 5, 2008 | 06:41 PM
Blade's Avatar
June 2007 ROTM
the car isnt tubbed is it?
wheliebar
Nov 21, 2013 03:23 PM
julacia001
Sep 14, 2011 08:28 AM
camaroboy68ss
Apr 30, 2011 10:59 PM
1971BB427
Oct 24, 2009 07:35 PM
Colt45az1
May 16, 2009 01:26 PM
