68 frame stand question
Old Aug 18, 2012 | 10:26 PM
hotrodguy696969's Avatar
Default 68 frame stand question
I'm working on a '68 Camaro. The distributor is up against the firewall. Meaning it's a touch away from rubbing against it. Dropped a 396 in it with a TH400 reverse pattern. Got the crossmember just holding the trans up now. My question is ... Is there a difference between a big block & a small block with the frame stand? As far as I know, this car had a small block with a TH350. Had a hell of a time to mount the motor to the stands & it seems like it's sitting just a hair too far back
Old Aug 19, 2012 | 07:55 PM
Or, should I call them engine frame mounts? Is there a difference between mounts for BBC & SBC? The dilemma is that the distributor is just about against the firewall & can't get the trans dipstick housing in place either.
Old Aug 19, 2012 | 08:17 PM
Big block frame brackets has the drivers side taller than the passenger side, to rock the engine to the right by 1". I've seen sources stating the big block brackets/motor mounts also move the engine forward almost an inch for more firewall clearance. Be sure to use a big block trans crossmember, or modify yours, so that the trans mount is moved to the passenger side the same 1". Without doing that, your engine/trans centerline will be tracking at an angle, throwing off your pinion angle (relationship between front & rear yokes), which can give you driveshaft vibrations and chew up your u-joints. Here are a couple of write-ups about the frame brackets:
Camaro - Engine
Camaro Engine
Old Aug 20, 2012 | 08:36 PM
Thanks for replying Camaro 69, nice link & very informative. Got a trans crossmember from '69 Camaro with a BBC & TH400. He changed it to a tubular one. If the mounts currently on the frame are from a small block & with the cap on, it has 1/8 - 1/4 inch clearance the 1 inch forward would be perfect fit.
bearfan
Jan 29, 2013 04:25 PM
78 on my plate
Apr 4, 2012 12:42 AM
pantherzcamero
Feb 26, 2007 12:06 AM
Blade
Sep 15, 2006 08:21 PM
Midnight Runner
LS Series Tech
Mar 5, 2006 08:56 PM
