1968 Camaro Header Equal Height At The Collector
Old Jan 20, 2020 | 02:31 PM
WelderDude's Avatar
Default 1968 Camaro Header Equal Height At The Collector
Should the headers, at the collector, be equal distance from the bottom of the car or does maybe the passenger side seem higher up and closer to the bottom of the car? Does it matter which header manufacturer it is? These are Hooker long tube. Engine is just a 350 cu.in. Thanks for any feedback.
Old Jan 20, 2020 | 06:15 PM
Everett#2390's Avatar
All three sets of Hooker's I've had, were the same, as this was in the '80's.
Old Jan 21, 2020 | 05:46 AM
flat tire's Avatar
mine as well are even.
if it bothers you, you can take something like a ball bat and insert in the collector and pry down. it will give some. just don't over do it
Old Jan 21, 2020 | 08:02 PM
Make sure you don't have a broken motor mount or something of that nature.
Old Jan 22, 2020 | 10:22 AM
Yes, ensure same tire pressure and size, engine square in frame, no rotten body bushings.
Explaining my comment 'were the same.' means the three sets of collectors were different heights as well.
Maybe an inch difference max.
Old Jan 22, 2020 | 02:45 PM
CO68Camaro's Avatar
Ahh, the great Hooker Equalizer experiment! I've had at least two sets of Hookers that didn't line up underneath - one set on a Vega and another on a 2nd gen Camaro. Both were evened up by using either a 2x4 or a 1x4 and a jack. I placed the wood between the header tubes and the body, and jacked up the collector until they were close. I couldn't have easily bent the other collector down, as ground clearance was an issue, especially with the Vega. It worked out great, though, and I was left with an equal exhaust system...that no one ever saw...
Old Apr 27, 2020 | 05:48 PM
Smee78's Avatar
Mine was equal when I had the 327 with Hooker long tubes.
Timeandmoney
Apr 11, 2016 04:08 PM
z28pete
Aug 22, 2011 07:47 PM
nine-six-zee28
Nov 28, 2010 07:03 PM
hundayguy
May 21, 2009 09:14 PM
mattvogt
Apr 28, 2006 12:27 PM
