Adjusting windows
Old Sep 17, 2013 | 12:09 PM
ragtag's Avatar
Default Adjusting windows
Now that its getting cold out I finally decided to roll up the windows and found that the glass in the passenger door overlaps the chrome edging on the quarter window. I'm told that I need to adjust the quarter window. I'm not sure how to do this. What do I need to remove to get at the mechanism and what do I do when I get there? Any suggestions or instructions would be appreciated.
Old Sep 17, 2013 | 06:24 PM
Scooch's Avatar
Super Scooch
January 2009 ROTM
I have the same problem, but only on the passengers side. when I roll it up I just stop short. but the wife always rolls it all the way up and then the front glass hits the chrome like you said. Im thinking Ill have to pull the rear panel to be able to even see the mechanism so thats probably a good place to start. I believe theres a metal tab in there that acts as a stop. It may be bent a little from all the years of ups and downs.
Old Sep 24, 2013 | 02:57 PM
KJW468's Avatar
There are not that many adjustments to it. There is the angle adjustment to level the window with the door opening or seal. There is the vertical limit, the adjustment to push the window against the outer rubber squeegee. and the bottom limit. I just rebuilt my doors and found that the 1/4 windows were not adjusted correctly and I rolled them down a little to mate with the trailing edge of the front windows.
Old Oct 14, 2013 | 03:18 PM
p3te's Avatar
sorry for the hijack but i think i also need to adjust my drivers door glass, there a gap between the glass and top seal near the pillar and also on the pillar its as if it dosent close onto the seal enough, are there adjustments that can be made to bring the glass toward the cab and onto the seal?
Old Nov 2, 2013 | 07:23 AM
p3te's Avatar
can anyone help that's done this before? ive tried searching old threads but the photographs weren't on anymore. ive took the panel off and took some photos, can anyone tell me what does what adjustment? or is there any that ive missed?
#1 -
#2 -
#3 - glass anti rattle pad?
#4 -
#5 -
#6 -
#7 -
#8 -
AmericanMuscle1989
Jun 16, 2013 03:32 PM
sante65
82-92 V8 Tech
Aug 15, 2009 10:42 PM
z28pete
Aug 2, 2009 10:43 AM
SSsuperdave
Mar 28, 2007 01:01 AM
HotRod53
Mar 8, 2005 11:35 PM
