Voltage Regulator diode? / Wire harness
Old Jan 31, 2011 | 03:57 PM
  #31
The 1% you didn't read must have included the part where Stovebolts said his alternator is also 1-wire capable, and he was taking that route. That's what all our previous wiring suggestions were based upon.
Old Jan 31, 2011 | 04:02 PM
  #32
StoveBolts's Avatar
Hey, thanks Massey!
You know, I was looking at that connector too!
If you can draw me up a picture, I'll make the changes next weekend. Also, I like the idea of a junction box where the four wires are bolted together by the Horn relay.
Thanks for your input!
Old Jan 31, 2011 | 04:30 PM
  #33
StoveBolts's Avatar
69, I certainly appreciate everybody's help! I have learned a lot for sure and only hope I can share some of the stuff I've learned over the years too! Like I said earlier, I'm somewhat color blind, so I've always shyed away from Electrical.
And to think, I was going to put a circuit breaker in where I should have had a fusible link
Old Jan 31, 2011 | 06:34 PM
  #34
RatCamaro's Avatar
I'm running a single wire alt from Jeg's. I run a mini starter with a external ford starter solonoid. what wire will I need to run on the run side of the solonoid to turn on the fuse block? Is it the black one that turns red?
Good topic
Old Jan 31, 2011 | 10:38 PM
  #35
Massey's Avatar
OK here are the schematics. The first is what you have in the car, and the second is how to change the wiring to meet the requirements of the Internally regualted using the ignition switch and plug.
Any questions just ask.
Massey
Old Feb 1, 2011 | 12:50 AM
  #36
Would it be asking too much for you to redraw those schematics?
The main lines are different from what's drawn. This factory wiring diagram will make it easier than describing:
http://www.gvtc.com/~rlaa/Electrical/68_1.JPG
Old Feb 1, 2011 | 05:29 AM
  #37
orocker's Avatar
December 2011 ROTM
Santas Little Helper
You can buy the loom tape in a roll, from resto companies. I've restored old Vette harnesses to like new condition this way.
We used a lot of different size loom with ours. Got it at Harbor Freight. Then wrapped it in tape. That way if we need to change anything we just cut the tape at the loom opening. Easier than unwrapping the wires.
Old Feb 1, 2011 | 03:19 PM
  #38
Massey's Avatar
I can fix it when I get home tonight. I see the brown wire is pink on Camaros. Lemme see what I can do. Oh and my art work will not be as pretty
Massey
Old Feb 1, 2011 | 03:36 PM
  #39
Oh, don't put yourself out. I was only kickin you in the nuts.
But you did get it a lil effed up!!!
Old Feb 2, 2011 | 10:04 AM
  #40
Massey's Avatar
No biggy... I didnt have Camaro Schematics to work with when I made those any way. I went off my memory from doing the conversion on 60's Chevy trucks and a couple of cars. I have even put the 7127 Alternators in Fords and Dodges. Anyway I was not able to get to my computer last night so I will have to fix the colors later today.
Massey
