Turn signal issue
Old Aug 10, 2017 | 11:16 PM
Rocky Citti's Avatar
Default Turn signal issue
My 68 had both signals working and the I noticed a solid green light when I turn the passenger side blinker on. Any ideas? The front and back light come on, they just don't blink.
Specs:
68 Camaro, Crate 350ci/hp, Edelbrock EFI, speed pro pistons, com cam and lifters, turbo 350 auto trans, Edelbrock ceramic coated headers, flowmasters, 10 bolt (non-posi), power steering, power disc brakes, HD tri-core radiator.
Old Aug 11, 2017 | 05:35 AM
flat tire's Avatar
check the bulb
clean contacts on bulb
clean bulb socket
check and clean grounds
trace wires
then remove steering wheel
Old Aug 12, 2017 | 04:01 PM
Everett#2390's Avatar
Try an old fashion 552 flasher rather than the 512 flasher installed.
Old Aug 15, 2017 | 10:08 PM
Originally Posted by flat tire
check the bulb
clean bulb socket
trace wires
The issue starts when I turn my light on. All of the lights and signals work prior to me during the lights on. As such, I'm good to go during the day. Must be a short, right?
Old Aug 16, 2017 | 06:40 AM
As suggested, clean grounds
You might run a ground jumper from bezel, of hose clamp the wire to light socket, if metal socket, as it should be, to the fill tube structure inside trunk.
There is a Phillips screw in place with a ground wire.
Also, check light socket wiring for the proper filament lite
Brown is tail lights, Yellow is left brake/turn, Dark green is Right brake /turn.
There is no short, if there was, fuses would be blowing and you have not mentioned of fuse replacement.
So it could be a miswire?
Old Aug 16, 2017 | 10:34 AM
makes sense, I'll get to work. Ty!
dsours69RS
67-69 I6 Tech
Aug 18, 2021 11:31 PM
Pro78z28
Jul 24, 2013 03:58 AM
JZ28
Mar 31, 2012 09:13 PM
nnewquist
Feb 18, 2012 09:55 PM
wolfy692005
Aug 14, 2011 11:20 PM
