Tans swap ???
Old May 27, 2018 | 12:08 PM
Camarokid520's Avatar
Default Tans swap ???
Hi all new member so sorry if I'm posting in wrong section hahhaha anyway have some ? I have a 67 with a 400 sm block with 2 spd power glide trans that leaks and I don't like it what I wanna do is put a 350 3 speed in it but never don't it before and wanna know if would have to get a different flywheel and cross member and drive shaft for it to mount up or are the trans basically just going to bolt up thx
Old May 27, 2018 | 05:24 PM
Y2K's Avatar
Y2K
You might have to swap the cross member out and get a driveline done, pretty sure the flywheel can stay but not sure. If you do get another flywheel/flexplate I believe it will have to be for a 400 engine because if memory serves the 400 is externally balanced like the 454 big blocks and flywheels do not interchange with other engines.
You might be able to just change the front yoke on the driveline, as long as it's a short shaft T-350 they are about the same length as a powerglide.
Old May 28, 2018 | 01:21 PM
Awesome thx
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
meteoralp45
Apr 7, 2008 03:57 PM
illumastar
Nov 9, 2006 09:45 AM
SlickWill
Aug 27, 2005 10:36 AM
